mate has a cheep one forsale, just wanted to know befor buying thanks
satans_child_nz,
May 2, 3:55am
if you can find an adapter plate or bell housing to connect the two. 350 z is a v6! so guaranteed youll need to find a way to join the box to the motor.
snowballs4,
May 2, 3:57am
its 6 speed nissmo box thats why i want it,
marmatt,
May 2, 3:58am
tried googleor a nissan fourm
tnt423,
May 2, 4:07am
Not a bolt on job, would need custom work to make it fit.
snowballs4,
May 2, 4:17am
thanks if i got it for next to nothingit would be worth it, gear tech would do that!
jsbike,
May 2, 4:27am
The 6 speed gtr box is known to be weaker than the 5 speed gtr box, maybe the 350z is the same!
I was told you could swap the bell housing from a 300zx box with one from a manual RB box to use the 300zx box.
snowballs4,
Jan 5, 10:10am
i just did some research, the 6 speeds are stronger than the 5speeds in the 350z, let again i dont want 6 speen i rather the 5, been told the 25det ones are the same gear ratio as the gtr, and the 25det ones are stronger, just want the car soild as, im runnning a 20det gearbox at tho mo thats fine, its behind a 600hp rb30 so i dont know how long its going to last. thanks for all your help
