Top engine mount.
wildcat1, Apr 9, 11:28am
failed warrant cos of a worn out top right engine mount. toyota windom they seem pretty straight forward to replace and install, is it exepnsive to get this done!
jasongroves, Apr 9, 11:33am
Generally pretty easy to do.
You need to take the weight off the mount by slightly lifting the engine with a jack.a soft bit of wood between the 2 will help level the load and prevent damaging the sump etc.
Not sure on price of mount but Yellow Pages should be able to help you there;)
johnf_456, Apr 9, 1:18pm
Try the mount shop
jmma, Apr 9, 9:13pm
Is that the name of a Brothel (o:
budgel, Apr 10, 7:06am
No, it is a place near Tauranga.
autocars1, Apr 10, 5:46pm
No simple as, talk to BNT and they will get one cheap. Easy to replace, take the weight on the bottom of the motor with a jack.use a piece of wood to spread the weight oin your sump.just take the weight.
johnf_456, Oct 17, 4:45am
