Hi has any one taken a starter motor out of a big horn do you take it out from the bottom of car or top looks like a pain to get to it
Mar 31, 4:43pm
you do what ever you need to some cars you have to remove the oilfilter to make room . and dont forget to first disconnect the battery .
petermcg,
Mar 31, 4:44pm
If its the same as mine it will be a prik of a job. The bolts go right through and have a nut on them, about 17mm spanner I think. You would probably get it from the top but you might also want to have some one underneath to hold aspanner on.
hondalova,
Mar 31, 6:53pm
just fitted a starter to a big horn. goes in/ out through top. P I T A to do. both bolts/ nuts are 17mm spanner/socket
karl137,
Sep 20, 3:44am
thanks for your help
