Similar to an escudo or the likes.Not a ute or if it is then double cab,smaller the better.Turbos ok as long as it diesel.Now do these exist!
dr.doolittle,
Mar 26, 7:51am
Why diesel!
1ollie,
Mar 26, 7:52am
lol an why 1300cc!
nutslap,
Mar 26, 8:03am
Oh oops,ok I meant to say and forgot,for farm use,no need to be legal etc and can be smaller than 1300.Why deisel,cheaper than petrol and why 1300,cheap to run.Sorry I didnt specify before,alzheimers kicking in
a 4x4 is heavyas poo to start off volkswagen make a 1.2 turbo diesel that car holds the worldrecord for lowest fuelconsumption of the line produced car. its called a vw lupo 3Liter tdi uses 2.99 liter for 100km distance and no its not a 4x4 its got magnesium seat rails and there likes and other waight savinggimmics.
Mar 26, 8:27am
there are diesel Quads for the job. or you could make your own diesel quad ;)
nutslap,
Mar 26, 8:34am
Quad still wet and on the farm we going to you have to go through a river that the boss states NO BIKES THROUGH RIVER as its too deep,gotta keep above water level,oh i could go on and on.Maybe just gunna have to go for the escudo,Im liking a Blizzard here at mo but its gearbox aint flash.1600 you say,is that in deisel too or just the 2lt deisel!And yea those SJ410/413s are good too :-)
Mar 26, 8:57am
suzuki never made no diesel thediesel are mazda crap untill about 2002 then peugeot and then renault diesel. these are expensive carsto use to drive thru river not to mention that they probably will stall when the electronics gets wet on the diesel. older suzuki had no diesel engine unless somone fitted one .
Mar 26, 9:21am
tell us what you need it for! just for flat farmland and thru a few rivers! you wont fit a diesel engine to a petrol for 500$it be more like 3 grand or more till your finished. I know it cost a grand just to change one engine for another that bolts straight on needing this andthat and some of them and woops spent a grand on hoseclamp pully gaskets .
Mar 26, 10:40am
you cant go in the water with a petrol nor with a electronic diesel.
unideck,
Mar 26, 10:45am
What the OP is asking for simply don't exist. Buy a Kabota 4x4, spend some money and if you are a farmer you will know running a car even if it is 4wd will not do what your asking.
unideck,
Mar 26, 10:48am
This is what the Life Saving NZ use here at Hot Water Beach. I get to service it every other month, good solid bit of kit ;)
Pap, intrade only ever reads what he wants to haha
elect70,
Mar 26, 10:52am
how about an old landrover deisel , ruggedwater proof engineno electronicsjust fit a snorkel if going in deep water . I had an old S11 , perkins deisel,slow as but it was good for river crossings where we had our hutt up the top of the Orongaronga valley(Wainuiomata ) in winter .
mrfxit,
Mar 26, 10:59am
Interesting thought . BUT how do the modern 4x4's get away with river crossings / 4x4 rally's etc.
Mar 26, 11:04am
you need to waterproof all things in theoryyou could go thru water with a petrol if you managed to seal all the ignition components from moisture .
noswalg,
Mar 26, 11:41am
What a crock of s@#t I've been through plenty of water in plenty of petrol 4X4's with no problems it all comes down to set up!
what about a John Deere gator! 4wd or 6wd. great engines. petrol and deisel. can fit a roof and doors. towbar and tipper tray.
nutslap,
Mar 30, 9:25am
Ok thanks for all your help,I am after a vehicle(not quad or the likes as it isnt rainproof,no im not a woos nor a witch that will melt but I do have small children and on the occasion they need to come out in the rain its best they stay dry,and the double cab/rear seats are needed + it will be used as a hunting vehicle no doubt)and the boss has specifically said no bikes thru river,not that this is a 2m deep river or anything but it is a rule and a rule is a rule after all,as for river crossing as papariccardo said,I dont need a submarine(although papariccardo said I was a "he" but never mind)it just needs to cross a shallowish river other than that,flattish farm work,tow soem palm kernel bins maybe when needed,all I was after was a cheap to run small 4x4 preferably with selectable 4wd and hi/low ratio,I figured the smaller the better and deisel is cheaper when you dont buy kms and regos but if a 1600 petrol is it then so be it,sorry to confuse and once again thanks to you all for your help
elect70,
Mar 30, 11:39am
Even old petrol landys can be made pretty waterproofup to headlight level , Farmer here just sold roughish1960 swbhardtop$400,no regbut went & box & trans okused as a fishing hack now .
