Mitsubishi 4g54 2.6
revn7, Feb 3, 9:36am
Hi,
I have a mitsi l200 ute. It had a horrible knocking so I pulled it down and the big ends were a mess even spun on the crank on one. And the mains showing signs of wear. Am I able to use a crank and conrods from a 4g54 out of a mitsi magna!
Thanks in advance
phillip.weston, Feb 3, 11:44am
yes you should be able to use crank and rods from a Magna 2.6. I would probably use the Magna pistons and cylinder for extra compression and better flow too - but make sure the inlet manifold port sizes match up.
revn7, Dec 7, 8:13pm
Thanks Phillip
