fixed, it is not going back up, stuck down, no problems till now, thanks
gammelvind,
Feb 13, 6:12pm
It's getting a bit harder to find some to fix the old 2002's these days.
Feb 13, 6:33pm
its even harder to fix the 2002 v12 7 series
fiatracer,
Feb 13, 6:34pm
shame it's not a common E36 or E46, because if it was, it would quite likely be the regulator which re a common fault, so parts/expertise common.
saxman99,
Feb 13, 6:49pm
If the glass goes down but not up then either the switch or the wiring is likely culprit.Try swapping the switch with one from a window that works.
Feb 13, 6:55pm
OP--are you getting the point here from our sarky comments. the question can't be answered without the year and the model. Likely its a e36 3 series and the part is likely the reg at around $250 for a new part
haventrader,
Feb 13, 7:32pm
Or simply the regulator. Can you hear the motor running! More details will help.
pup2,
Feb 13, 7:37pm
But only the silver ones are $250. Red is another $300. And don't even start on the blue ones
elect70,
Feb 14, 12:27pm
Pull door card offsee if it is still engaged on thegear wheel .
foxdonut,
Feb 14, 12:32pm
Lucky its a BMW _CAR_ and not a BMW bike. Replacing electric windows on those is a bit of a mission these days without the special _TOOL_.
