2005 Holden SV6 fuel flap
limehosting, Feb 21, 12:43pm
Any one had issues with these releasing correctly! Cable is fine the flap itself just doesn't open when the cable is pulled, you have to manually pull it open
mattyj5, Feb 21, 1:41pm
There is a little spring in there.all you need to do is give it a bit of a bend to give more tension to pop the door open.
