Battery light,351 cleavland
perry111, Mar 3, 9:12am
hi, i have jus replaced the altinator on mi old ladys 1954 f100,she thought the alternator was buggered so went and got a brand new 1.i put it on correctlybut the battery light comes on when i start it! what causes this
gmphil, Mar 3, 12:32pm
Does it have fuseable link! This mayb blown
quickbuck, Mar 3, 1:20pm
Make sure your earth cable is properly earthed. Over time corrosion can get under it causing similar symptoms.
ceebee2, Mar 3, 3:30pm
Is the light on when key is on but engine NOT running!Does the lamp go out if you give it a quick rev! If so then the dash bulb wattage is incorrect.
supernova2, Mar 3, 8:08pm
Was the problem there before you started the job!Why did she feel she needed a new one!
