Ba falcon hot start probs
jason18, Mar 28, 10:39am
Every so often the falcon 03 decides to start then suddenly dies. Start again then dies.Start again and keep a little bit of throttle down and its fine. Only happens every so often and only when running and turned car off for around 5-20mins
n3d4sp3d, Mar 28, 5:31pm
ECU fried !
jason18, Mar 28, 6:10pm
I have been told to check the fuel filter out so will replace that first
don_logan, Mar 28, 6:56pm
Cleaned Throttle body!
gunhand, Mar 28, 6:57pm
Kinda like its flooded!
unbeatabull, Mar 28, 7:23pm
Clean Throttle body and Reset the Adaptive learning (if don't have Ford IDS disconnect battery for 30 secs and reconnect)
Clean the earth straps from battery to chassis rail, and chassis rail to block. After that, start looking at intake leaks (Manifold gaskets are relatively common), blocked or broken PCV Valve, block air filter, fuel filter etc. Blocked fuel filters tend to restrict power rather then make hard to start in these.
