Engine stall on sharp left-hand curve
davidgb, Apr 11, 7:01am
Hello everyone. Any idea on what could cause a car to stall when going through a left-hand curve like motorway exit!Car is honda odyssey 1999.
gmphil, Apr 11, 7:02am
Not enough gas!
davidgb, Apr 11, 7:06am
Just below the half full marker. I do notice that in doesn't stall when full. Could it be the fuel pump!
gmphil, Apr 11, 7:21am
When was fuel filter last changed !
tonyrockyhorror, Apr 11, 8:02am
I'd go with insufficient petrol too. Given it only happens turning left check to see if the fuel pump is on the left side of the tank. If so, given it only happens when the tank is below a certain level, I'd go with a blockage in the swirlpot.
davidgb, Apr 11, 8:34am
Thanks for replies. Will have a look at fuel pump and filter this PM.
rbjz, Apr 11, 9:41am
Could be more simple, is your battery secure!
pete_iam, Apr 11, 12:18pm
doubt its petrol. engine dont stall instantly when its a fuel issue when taking a sharp corner
n1smo_gtir, Apr 11, 12:46pm
yes, more likely loose battery terminals.but when the car is running, the battery does nothing other than getting charged up by the alternator which also supplies all the power to the car while engine is running. could also be a loose connection on the plug going to the ECU or loose connector or dirty connection on the plugs connected to fuel injectors, high tension lead or distributer. does it stall when taking hard right turns also!
