Best oil for EVO7
bevharris1938, Apr 27, 10:00am
Not standard car , larger inj. computer remap. Ive owed rotories all my life , 1st performance 4 cyl. Mineral ! Synthetic ! what weight !
phillip.weston, Apr 27, 10:20am
full synthetic 5W30, 5W40, 10W30 or 10W40 would be fine. I use Elf 5W40 full synthetic in my 200,000kms 4G63 Evo engine and it doesn't use a drop.
bevharris1938, Apr 27, 10:26am
Thanks Phil , change every 5K or 10 K
esprit, Apr 27, 10:30am
woulda thought a 30 hot weight oil to be too light for a 4G63. if using it hard that oil would get pretty darned thin.
a.woodrow, Apr 27, 10:45am
5k if it were mine - oil is cheap insurance on a performance vehicle
bevharris1938, Apr 27, 10:51am
Ripco having a sale this weekend , can get 5L for $56 Valvoline full syn.
phillip.weston, Apr 27, 11:24am
Not for a 10 year old 4G63. 30 weight is just fine. If it were pushing 400+hp on a standard bottom end then I would probably move to 40 or 50 weight.
clark20, Apr 27, 8:22pm
I like Castrol Edge,and their new titanium range
rednsr, Apr 28, 8:08am
Their marketing department has done a good job then.
There is nothing special about castrol oils. If there were they would have a lot more presence in motor sports.
I use Total lubricants 5w50 full synthetic. But then again I get that for forty dollars for five litres.
johnf_456, Apr 28, 8:31am
oil is cheap do it every five its not a corolla.
clark20, Apr 28, 1:04pm
angry.red, Apr 28, 1:17pm
yeah 5w30 is fine, thicker oils seem to make lash adjusters tick
n1smo_gtir, Apr 28, 1:26pm
i'm not for or against castrol but to get your info straight from castrols site doesnt really say diddly swat. How many manufactures do you know bags down their own product on their own website. try one from another reliable source be more credible.
jason18, Apr 28, 1:32pm
I think clark20 is meaning castrols involvement in motorsport.Where it was mentioned earlier that they didnt have much involvement
designerliving, Apr 28, 2:23pm
Castrol have had significant involvement in lemans (probably the most demanding motorsport event on earth) for a very long time.
mrcat1, Apr 28, 3:56pm
The only way to know how well a oil is going in a particular engine is to sample it, end of story!
Manufacturers can whip up any tripe but the proof is in sampling, makes me laugh when someone swears by a certain oil that its the best, but they have never done a sample on it, just manufacturers spin doctor at work.
clark20, Apr 29, 11:12am
Proof may be in the sampling, but how many oils have been proven to be at fault, rather than using the wrong grade, it got too hot, it was used for too long, it was not topped up, it had contaminants in it, the engine was worn, the pressure wasn't high enough etc etc
mrcat1, Apr 29, 10:03pm
Thats the whole point in sampling, it will tell you if you have contaminants (fuel,water, debri), if it was used for to long, excessive wear, its got to hot and the oils broken down. But how else do you prove that a oil is doing its job properly and not causing excessive wear! Listen to the oil companys spin doctors!how does saying a certain viscosity oil is the best! when one of the main things in oil is it's spec, if it doesn't meet a certain manufacturers spec then the viscosity doesn't matter at all.
