Until you know exactly where its coming from the answer to that is no.Firstly you are going to have to clean the whole area where the leak is and then determine whether its engine or trans oil that is leaking.
johnf_456,
May 31, 8:06pm
As above use some degreaser clean up the engine and gearbox then go for a drive and see where it comes from, even take a torch with you if need be.
jasongroves,
Apr 24, 12:43pm
Wasn't fitted correctly! Or wasn't the fault in the first place.
