The pulley bearing in my AC pump has gone. The engine is a Toyota 2C-T. If anyone can cross-reference the pump and tell me what model it is, or the part number etc, which will enable me to check the bearing part number without stripping it down first I'd be most grateful!
Wow! A parts cross-reference that actually works, and actually has every model listed! Brilliant! Cheers mate, hugely appreciated!
faa_luke,
May 25, 10:06pm
I use it all the time. Can't guarantee it's 100% correct, but it's a start.
tinker1,
May 27, 8:51pm
If you can tell me what year it is and type of pump or any numbers off the pump I could. I would guess it is an old corolla or similar and have either a Denso TV10 or TV12 compressor, if thats the case the pulley bearing is 30x52x22 which is a 30BG05S2G-2DS. Just be sure it has not damaged the front housing of the compressor before fitting the new bearing.
