Were Toyota's Using R-134a Air Con Gas In 1993?
ema1, Apr 29, 6:26pm
Were Toyota J.D.M.cars using R-134a gas or R-12 in 1993. &what does a 1993 system need in a retro fit to R-134 if it is indeed a R-12 system !
AE 101.FX-SJ Corolla in this instance.
franc123, Apr 29, 6:45pm
1993 was when most manufacturers were starting to change over, could possibly be either,If there are no stickers under the bonnet stating whats fitted and what the oil and recharge capacities etc are, have a look at the charge ports, the R12 ports are quite small compared to the 134a ones.Retrofitting is normally a case of fitting new screw on charge ports, thoroughly evacuating/vacuuming the system, replacing the drier and recharging with the newer gas and new compresser oil.The problem with doing this to these old systems is that they are way more prone to leakage, either quickly or over time, the flexible hoses, seals and O rings used throughout the system aren't made for the finer molecule structure of 134a.On most cars it isn't really worth it.
pup2, Dec 25, 4:03am
R12 fittings will have a thread on the outside of them. R134A fittings ane quick release with a thread down the middle. What a R134A fitting looks like in the link
http://forums.bimmerforums.com/forum/showthread.php!t=1260796
