I figure with the amount of 1999-2004 mazda familia sp20s i see driving around someone on here must have an idea of what it cost to get a cambelt done on one!Ours has just rolled over 90000kms so want to get ready for the bill. At this stage will be doing it at the dealer to maintain proper service history for when it comes time to sell Thanks
pfemstn,
Jul 4, 6:19am
ive got a sp23 and it does NOT have a cambelt!
fordcrzy,
Jul 4, 6:51am
thats because its a sp23 and not a sp20. the sp20's have the older BP based engine.
TO THE O.P. get the water pump replaced while you are doing the cambelt it is good to get it done while everything off the front of the engine
ninja_man,
Jul 4, 6:58am
my sister just did hers on her sp20 (water pump and cambelt), cost around $650
fordcrzy,
Jul 4, 6:59am
that sounds about right
panicky,
Jul 4, 7:58am
SP20 is the FS motor.
fordcrzy,
Jul 4, 5:27pm
which is very similar to the bp.its totally different the rest of the F range
fordcrzy,
Jul 4, 6:18pm
wow do you get a prize for stating the freakin obvious. my point is that the SP20 motor is not the same as the MZR sp23 motor and is more similar to the BP motor in terms of servicing costs and labour. the FS also has a completely different block in terms of bore spacing and deck height.closer to a bp than the other f series
shazza541,
Jul 4, 7:05pm
awesome thanks for the replies people
biddy6,
Jul 5, 4:40am
If your going to get it done @ the dealership, just ring them.
