Front wheel bearing replacement cost
shore_girl, Mar 6, 7:02pm
Hi, what is a fair price to replace the front wheel bearings on a 2003 Mazda Demio! TIA
incar., Mar 6, 7:18pm
$250-$300
shore_girl, Mar 6, 7:44pm
I assume that's for both sides to be done!
incar., Mar 6, 8:40pm
you assume wrong, 1 side
shore_girl, Mar 6, 8:52pm
Cool thanks for that, car is going in for a service on Friday so will get them to investigate further. Thanks for your help.
r.g.nixon, Mar 6, 8:58pm
Interesting. I might keep driving on mine until it breaks. I only use this car around town, so should be safe enough.
incar., Mar 6, 8:58pm
all good, if they tell you, you need both done get a 2nd opinion
intrade, Mar 8, 7:42am
wheel bearings usuually are a wof fail and the worst i seen is on rav4 the cv joint snapped off seems to be common for all to do this onleft front , but otherwise you can drive for years on a worn front bearing , makes ghost like noises when you drive slow some can be adjusted when there is a crown nut on cv with split pin like on dahatsu mira early 90 for example
