Tyres are.185/ 65rsteel belted Radials, cant find the PSI on them, also is the back tyre pressure different from the front. as.it was on my last car.
Cheers.
callum.irvine,
Jun 4, 1:41pm
Think it is more dependant on the car than the tyre. All the cars I have owned have had the recommended pressure somewhere on the drivers door insert, or the door itself. Of course, if you have aftermarket wheels, the pressure could be diff to the recommended one there. The pressure on the actual tyres is usually just a maximum allowable.
petermcg,
Jun 4, 3:49pm
32 PSI
johnf_456,
Jun 4, 3:53pm
32 to 34 but no idea on car
jasongroves,
Jun 4, 3:54pm
What is the vehicle! Are they factory wheels and tyres!
mrfxit,
Jun 4, 4:29pm
A start for general usage would be .
FWD = 28psi rear / 34psi front RWD = 28spi rear / 30psi front
Tyre size is almost but not as important as vehicle type & usage
shortee2,
Jun 5, 11:51am
Thankyou for the answers.the Car is a'' Toyota Ist'',gets usedevery days.
Cheers.
lyonruge,
Jun 5, 11:56am
32psi all round will be fine
shortee2,
Jun 5, 12:15pm
Thankyou.
dan.kev,
Jun 5, 3:27pm
32 psi all four tyres i work for a tyre co
mrfxit,
Jun 5, 5:08pm
Whatever you say, can't go wrong with a Pro aye . Depending on what it's used for themost> >>
32 ok front for trips 34 front around town 28 back with just a driver 32 back with moderate loads
Tyre shops NEED tyres to wear out or they don't make sales (but not that fast that ppl click to it) Car manufactures set a compromise psi that will "work" ok in most situations but won't get the best wear overall for specific jobs. Because NZ doesn't make cars, the pressures are set for most overseas roads of a totally different road surface type & fairly flat roads compared to NZ's "goat tracks & 4 seasons in 1 day" climate.
shortee2,
Jun 5, 7:37pm
So your saying i should i should have a different pressure front and back!
Its a Toyota Ist,one person usually , the Driver.no big loads. from what you have put that would mean. Front 34 Back 28
Or have i read it wrong!
mrfxit,
Jun 5, 9:20pm
Most likely the case is yes. I am unaware of the vehicle's gross weight but thats about it in a nutshell
Try this as an explanation (of sorts) . 300kg per wheel at 30psi wears the tread evenly 250kg per wheel at 30psi will wear the center of the tread faster then the edges. 350kg per wheel at 30psi will wear the edges faster then the center of the tread
Front tyres at 30psi /300kg per wheel & turning corners, wears the edges faster but is compensated for (in part) by running higher pressures.
The back of most vehicles is lighter then the front. On a FWD you have the motor /gearbox & diff ALL sitting over the front wheels & only a light weight trailing axle in the rear of that same vehicle.
A RWD vehiclehas the motor over the from wheels/ gearbox between front & back wheels, & a substantial diff in the back of that vehicle
mrfxit,
Jun 5, 9:26pm
Just checked your vehicles size & would most likely go with 34psi front & 30psi rear. Part of the tread wear belongs to HOW you drive it & WHAT you carry.
I know of many ppl that can't get more then about 25,000kms from a front set of NEW 265/70/15" 4x4 tyres. My Surf still has the same set of barely wof tyres on it after 20,000kms & 3 years later STILL got a new wof last month
shortee2,
Jun 6, 12:20pm
So glad you clarified things with that second Post, that first post was looking a bit Technical, as all i wanted was the PSI, not a long involved explanation.So thanks.
mrfxit,
Jun 6, 1:25pm
To get the best wear & handling, you need to understand WHY the Fwd/Rwd Weight /Road type issues are important.
Little wonder the tyres companys laugh so hard at the general population
