you want cheap use your own mark 1 eyeball. you want a proper job pay proper money
gmphil,
Jul 10, 3:38pm
Wots cheap! My guy does $45
familiadude,
Jul 10, 4:33pm
^^^^ where is that gmphill!
andrea_w,
Jul 10, 5:41pm
I got my last wheel alignment for a box of beer :D I can tell you where he is but I certainly can't promise you'll get the same deal
nicolag,
Jul 16, 8:01pm
JP tyres glenfield from $35.00
ontwowheels,
Jul 16, 8:09pm
I dont recommend that having tried that, worst alignment ever! think it was when i replaced a power steering rack and a tie rod at same time on commy. Eyed it up, might have even measured it a bit. Damn it was bad. One drive to the alignment place chew out the edge of my tyre. Luckily it was beeing replaced anyway!
bill-robinson,
Jul 17, 5:04am
As I said
gypsypom,
Jul 17, 5:17am
want it cheap, use the eyeometer otherwise pay the bucks
johnf_456,
Jul 17, 8:04am
Yep, which is why you count how many turns you undo the tie roads.
have already done the wheel alignment. Car still pulling to the right, think i need a new caster.
bill-robinson,
Jul 17, 10:38am
you mean that the job you had done did not include castor!
vr4_legnum,
Jul 17, 3:51pm
Have you try moving the right front tyre to the left front and left front tyre to the right front and taking it for a drive and see if it pulls to the left!Cause if it does that, It be the tyre, Not the wheel alignment.
turton,
Jul 17, 3:54pm
il give that a go, thanks for the advice
turton,
Jul 17, 3:54pm
as far as i know, the caster on my car is non adjustable. Car in question is a 97 integra type r
bill-robinson,
Jul 18, 5:22am
you said it
Jul 18, 6:12am
cheap string methode on youtube
newtec1,
Jul 18, 5:38pm
What do you call a wheel alignment.If you just want toe in-toe out you can do it reasonably accurate with lines and measure,but if you want a real alignment you need to put it on the machine and do caster& camber.
icemans1,
Jul 18, 11:30pm
pedders on patiki rd, avondale, west ak. not cheap but but highly recommended. the guy has done a lot of competition cars
rEtyre,
Jul 22, 6:03pm
you don't buy caster, you adjust it during a wheel alignment. However you probably need new tyres. 99 percent of all problems with cars pulling one way are caused by tyres, not mis alignment.
turton,
Jul 22, 6:12pm
i assume the tyre shop adjusted the castor (if adjustable) whilst doing the wheel alignment, so could be something else causing the car to pull to the right. Have also noticed a scraping noise when cornering fast :/
rEtyre,
Jul 22, 6:17pm
Not likely. Most probable cause is a separated tyre. Take it into a reputabletyre dealer and get them to check your tyres.
ontwowheels,
Jul 22, 6:21pm
I did that, but in this case it was horribly out, may have been a difference in the parts I don't really recall the full details. It was only done by eye/ measurement with tape measure to get it from homw to place that stuck 4 new tyres on and did an alignment. Horrible to drive none the less!
bevharris1938,
Jul 22, 6:52pm
From $35 , is that for 2 wheels !
bill-robinson,
Jul 23, 5:20am
No just one
