1994 ford fairmont
jackfish, Aug 8, 5:05pm
heater only blows out at your face and not feet or demister can any one please help
nzshooter01, Aug 8, 5:06pm
had similar with my commordore, vacum controled, hose had brokern at vacum takeoffback of head, put hose back on problem gone!
jackfish, Aug 8, 5:18pm
will check it out thanks
nzshooter01, Aug 8, 5:26pm
shouldnt really have told you seeing as you drive a ford,lol, but ill make an exception, you might have to look for the small dia rubber hose that will come out of the firewall somewhere and travell along and no doubt disapear to some damm awkard place, good luck
jackfish, Aug 8, 5:51pm
i can understand how hard it was for you to answer the question.once again thank you and i wont tell any one.
crzyhrse, Sep 23, 5:03am
Blowing on the windscreen is default for no vacuum. So it's not that.
Most likely a jammed door.
