as i was puting the wheel nuts on my car on of the studs pushd threw the hub n so now the nut spins freely with the sud in the hubhow could i fixd this!
Aug 2, 3:45pm
What kind of car is it! Disc brake or drum!
lisa.leann,
Aug 2, 4:39pm
silvia n disc
petemun,
Aug 2, 4:45pm
Hammer it back through or put some washers on and wind the nut to bring the stud back through. Hope I understand you right !
lisa.leann,
Aug 3, 5:29pm
the stud spins freely in the hub so if i wined the nut the stud spins n have knw acess to the back of the stud has brake caliper n disc sheild in they way
thunderbolt,
Aug 3, 5:32pm
The stud has splines at the base which press into the hub and lock the stud.
If the nut is jammed on the stud then it has moved beyond a job you can handle.
P.s. I derserve a fricken medal for making any sense of your last post.
gammelvind,
Aug 3, 5:44pm
You sure do lol
