Hey guys, I have a nissan pulsar 95 blue which failed its WOF due to rust in the door hinges.Does anyone know of a cheap place to get this fixed or know of any independent workers who would like some cash! this is a second car that I was meaning to sell anyway.would it be better to fix and sell or sell as is! .TIA
Jul 29, 7:15pm
rust IN the door hinges or rust in the doors or pillars that the hinges hang on!
johnf_456,
Jul 29, 7:16pm
I am a little confused of what you mean, any chance of a picture when the weather is fine.
monzo88,
Jul 29, 7:19pm
i have pictures but not sure where i could put them for you to see! the rust is on the door hinges themselves and inside the panel (when you look down by the hinges you can see the rust is down inside as well)
Jul 29, 7:23pm
monzo Id be fairly suprised if its rust on the actual hinges. You need to look up a local rust repair specialist
Jul 29, 11:20pm
in any case you have to remove the door. and reconstruct the damage with new plate welded depending where it is and if there is space for a cheap bash-weld-job or if you have to cut parts and rebuild it to enable correct working . can be not worth it.
