1996 Integra Door Lock
sxcstar, Dec 2, 6:06pm
I'm half way through installing the alarm in my car but for the life of me cant find the door lock wires, has anyone installed an alarm and be able to tell me where they are!
jono2912, Dec 2, 9:36pm
Does it have a central locking switch!
sxcstar, Dec 2, 9:51pm
No doesn't have a switch unfortunately
curlcrown, Dec 3, 8:44pm
Some don't have central locking.
jono2912, Dec 3, 9:05pm
I was assuming they did, as OP is looking for door lock wires.
curlcrown, Dec 4, 5:13am
I assumed they did too, until I tried to get one "repaired" only to discover there was no central locking.
sxcstar, Dec 4, 1:31pm
yup my car does have central locking with the key, will i just need one to connect to the drivers door or one for passengers as well! 2 door integra by the way
a18a, Dec 4, 1:35pm
you should only need one then, for the drivers door
the 5 wire one like jono said
jono2912, Dec 4, 8:37pm
Just the drivers door.
Let me know if you have any problems and I'll give you a hand.
sxcstar, Dec 6, 9:32pm
Ok have the alarm all in going but now just need ti find the turn signal wires. Have one for left and one for right, where are these! All online I can only see they tell you where the park light wire is, but my alarm has turn signals instead, which I prefer.
suplyuparts, Dec 6, 10:06pm
they should the green/yellow an green/red on the top behind the steering wheel.just run them in to those wires.if need be run a test light if you wanna find which is left an right.but.doesnt matter as they be running at the same time.
suplyuparts, Dec 6, 10:07pm
an can just use the drivers door for the unlocking.an locking
sxcstar, Dec 6, 10:25pm
I did just use the drivers door for those. ok will try that wires. thanks
jono2912, May 10, 7:50pm
Do you have a probe light!
