Hi I got a Honda oddysey here with no spark, its a f22b engine. When I to the dizzy cap off oil leaked out of it. I take it this is not right! Can be fixed or just get another dizzy!
Jul 26, 10:29am
Easiest and quickest solution would be to replace the dizzy with a second hand one. What's happened with your one is the internal O ring or oil seal has failed and you'll need to strip the dizzy apart to replace it.
Just keep in mind that a second hand dizzy will cost more than a brand new O ring.
tristanchev,
Jul 26, 10:36am
But would the oil have wrecked anything inside the dizzy! Can get a new dizzy for $195
bigfatmat1,
Jul 26, 11:07am
If it was me I would strip it and replace oil seal and bearing if the car still goes it might not of damaged anything. Other option as above replace dizzy
