Repair rubber inlet manifold on quad bike engine.
daryl14, Jul 21, 3:44pm
Just got a tear in the rubber intake pipe. Has a two bolt flange at each end, possibly with a steel flange moulded inside the rubber.
Best ideas for a cheap easy fix! I'm leaning toward going to a tyre repair shop.
NZTools, Jul 21, 3:47pm
wipe a bit of black rtv into the tear and let it set.
rob_man, Jul 21, 4:15pm
Urethane is better, silicone was the miracle material of the 1970s. Just make sure you clean it well first.
motorboy2011, Jul 21, 10:21pm
got a honda copy motor! inlet pipe has a slight bend in it!
daryl14, Jul 22, 9:30am
Nup, It's an older Yamaha YFM 200 - 250 air cooled, shaft drive with reverse. It is bent slightly to one side tho. Might be keen to bin it and go for a 400 ish engine.
muzz67, Jul 23, 4:59am
electricians shrinkwrap.
andrew241, Jul 23, 5:10am
That intake tube on the yamaha needs to be sealed propley.Try NZ Farm & Trail probley cheaper than you think.Luke on 07 8717321.We have had this intake pipe split ourselves,bike will backfire and run like a hairy pig or will run lean at high revs and melt a hole in the piston like mine did.
daryl14, Jul 23, 2:48pm
Hey thanks a bunch. Went and saw Luke today. Very helpful guy!
saki, Jul 23, 2:51pm
Go to a dive or fishing shop and get some stormsure or aquaseal
