Is there air in my brakes?
kucoo, Sep 1, 9:46pm
work fine most the time but sometimes go to the floor. do they need bleeding!
a.woodrow, Sep 1, 9:49pm
That would be a start. You also might have a faulty master cylinder
pollymay, Sep 2, 2:43am
Put your foot on the brake and hold on the pressure. If it slowly sinks to the floor the master is probably corroded from water and leaking past the seals
brokebloke1, Sep 2, 5:53am
you shouldnt be driving it if the pedal goes to the floor, trailer it to a expert before you kill someone.
