What oil
cdjtrading, Aug 11, 11:14pm
for a 2002 subaru legacy GTB E tune twin turbo done 120ks and how many litres! thanks
carclan, Aug 12, 7:26am
Check the mobil lubricant website as it is quite helpful
thejazzpianoma, Aug 12, 8:28am
Yip, Castrol and Penrite (and no doubt others) have "lube guide's" as well. You just enter the car in the box and it looks it up.
cdjtrading, Aug 12, 6:15pm
they told me to run 5w30 i think thats a bit thin for a 120ks sub anyone think 10w40 would be good! full synthetic of course, if so how many litres exzactly 4 2002 gt sub!
unbeatabull, Aug 12, 6:24pm
I'd possibly look more at a 10w30 but 10w40 should be fine as well.
supernova2, Aug 12, 7:19pm
Delo 40 sounds good to me; after all it's a subby.LOL
cdjtrading, Aug 12, 7:25pm
10w30! y do they need such thin oil! any1 got any ideas how much they take! ive heard exzacty 4 litres but cant confirm
unbeatabull, Aug 13, 5:17am
Its a modern car . If the manufacturer recommends that oil, that is the oil it should have. all the tolerances inside the engine etc will all be set up for that grade of oil.
llortmt, Aug 13, 7:21pm
moderate climate (ie NZ) 10w40 semi synthetic.
poohbear011, Aug 14, 3:30pm
4.5litres with new oil filter, i usually use castrol magnatec in subarus which is 10w 40 or valvoline 10w 30 on my rebuilt engine
201, Aug 31, 9:23pm
From my experience (28yrs Mobil Oil) I can tell you the Engine manufacturers tell the Oil company what viscosity oil is required. So if a 5w-30w oil is recommended then it will most likely have very fine oilways & hence 5 weight will circulate on start up just that bit faster. Zero degrees for a car having sat outside all night is not "a moderate temperature" and if itssay a 20 weight oil then the oil pump is going to be having a hernia trying to get it around the engine. cheers . P.S. decent oil is the cheapest insurance you will get !
