2000 Toyota Opa - Oil filter
proracer, Aug 18, 8:22pm
What Ryco oil filter is the corrrect one!
jmma, Aug 18, 8:28pm
A round one (o:
Try here http://www.rycofilters.com.au/
treachug, Aug 18, 8:30pm
What size engine david!What model, TA-ACT10 or TA-ZCT10!
proracer, Aug 18, 8:35pm
1.8
proracer, Aug 18, 8:37pm
ZCT10-0012797
treachug, Aug 18, 8:38pm
Z386
proracer, Aug 18, 8:39pm
you try smarty, it does not have Opa. i looked earlier.
proracer, Aug 18, 8:40pm
thanks for your help.
treachug, Aug 18, 8:42pm
Price a AC022 oil filter at your local Holden dealer as well .Thats the AcDelco equivalent & you may be pleasantly surprised.
proracer, Aug 18, 8:43pm
treachug, Aug 18, 8:45pm
Nz catalog lists the imports.
http://www.ryco.co.nz/
proracer, Aug 18, 8:48pm
I see 2 x Z386 oil filters on Trademe for $15 buynow. good deal.
treachug, Aug 18, 9:00pm
Yep, not bad & in your area too - save yourself shipping
proracer, Aug 18, 9:11pm
what oil grade you recommend!
kazbanz, Aug 19, 6:00am
proracer with the Opa mechanicals oil filter plugs etc you are better off using the engine number because the same engine is used in a lot of Toyota product.
The oil grade is reccomended as being 5w40 but in dauckland where the temp never gets to sub zero you can use 10 w 40-The VVTi needs the thinner oil on startup
proracer, Aug 25, 7:31am
Took old filter off and it a Filtercraft Filter FO2503 witch is same as ryco z101. why the size difference to ryco z386
thunderbolt, Aug 25, 8:55am
Because some workshop fitted whatever they had on hand that matched seal and thread sizes at a guess.
xs1100, Aug 25, 1:56pm
thats why go by engine number and 101 probably has a bigger capacity but will have the same pressure on the bypass so not really a problem
