97 izuzu bighorn 3.1 dieselautomatic ,ever since the previous owners and my self have owned the truck the little green 4 wheel drive indicator stays on the dash whick inlumiates in green colourits definetly in 2 wd and the 4wd works fine when engaged ,question is does anyone know where the sensor is located on the vehicle as i have looked around gear lever under truck and cannot find it,it not a big problem but if its an easy fix i would do itthanks
Sep 9, 6:00am
black duct tape-problem solved.
matthew_129,
Sep 9, 10:18am
Auto or manual locking front hubs! If auto could be indicating that the front hubs are not unlocking
nz2293,
Sep 9, 10:20am
it will be around the trans i remember our work 1 you use to have to wriggle trans back and forward
treachug,
Sep 9, 12:03pm
Yep.have you backed back approx 2 mtrs after selecting 2wd! This disengages the hubs. Even though auto hubs, with Isuzu you still had to reverse 2 mtrs after selecting 2wd. The auto part of the auto hubs mean that if in auto you dont have to get out & manually turn to 2wd.
mrfxit,
Sep 9, 12:10pm
Yep even tho the hubs are auto on my Surf, I STILL back up a bit because I have been caught out in the past where the hubs have stuck on.
evotime,
Sep 9, 12:14pm
Haven't they got "shift on the fly" a sliding gear on the left side of the front diff! I could be wrong! If it does there will be another 22 or24mm filler plug to the left rear side of the diff head, hard to see and I can't remember how it works, but from memory a vacuume operated slide instead of free wheeling hubs
geminidragon,
Sep 9, 6:07pm
hmm it certainly engages the 4 wd when being selected as it gets me out of the mud ok when 2 wd would not ,i dont think that i,m driving arround in 4wd all the time or i would notice it ! or not ,put it this way once i,ve got out of the muddy stuff i select 2wd again and all is normal but hey ill try what you guys say and get back to you if the light goes out cheers
geminidragon,
Sep 9, 6:08pm
i have auto hubs
geminidragon,
Sep 9, 6:21pm
just tried the backing up thing after going from 4wd to 2 wd and light stayed on thanks anyway
treachug,
Sep 9, 6:53pm
Switch is on on transfer case - right hand side near front of case, part number 8971386320 callled transmission range indicator switch. Suits '11/95 on UBS Bighorns
treachug,
Sep 9, 6:58pm
Shift on the fly was introduced with '98 on Bighorns with 3.0L 4JX1 diesels & 6VE1 petrol
geminidragon,
Sep 9, 7:24pm
treachug is this a serviceable part
treachug,
Sep 9, 7:36pm
Yep, thats the part number - take it along to your local Holden dealer & see what its worth. Not sure if its the cure for your problem.but its the only switch on transfer case. Part number may supersede but at least you aint gonna wait while they try to find the listing.lol
geminidragon,
Sep 9, 7:49pm
hey thanks i,m also looking for the switch that makes the beeper and reversing lights work , any ideas cheers
treachug,
Sep 9, 7:57pm
Damm, just shut the laptop down with the Holden parts program on it (now on desktop just checking emails). Have made myself a note to give you the part number - check back tomorrow night!
outbidyou2,
Sep 9, 8:02pm
Those models (bighorn, Mu) are pigs. Death to them ALL
fryan1962,
Sep 9, 8:17pm
my landrover discovery took a fair bit to unlock I used to back up go over uneven ground
hope you sort it
geminidragon,
Sep 10, 5:24am
i dont think its locked in 4wdbecausewhen i,m stuck in the mud in 2wd then select 4wd it pulls it out ,i then go and select it to 2wdand all back to normal other than the 4 wd light staying on
treachug,
Sep 10, 7:11pm
Reverse light switch (assuming its a manual) part # 8971659510.found on left side of box, just under quadrant box
geminidragon,
Sep 10, 7:33pm
thanks treachug but mines a auto :) do you have a number for that cheers
treachug,
Sep 10, 7:48pm
oh yeah.duh.just re-read your first post again.lol Inhibitor switch is on the left side of the trans, look for where the shift rod attaches to the trans. Unsure if the switch is a good number in nz but worth checking. Part number should be 8960176200. Not cheap im picking.second hand may be better option!
