CV boot replacement in a Toyota Celica
brendazworld, Sep 22, 8:09am
Hi auto-brainiacs!could you let me know a ball-park figure of what I can expect to pay to have a CV boot replaced in a Toyota Celica please!TIA!
therafter1, Sep 22, 8:25am
Wasting your time just doing the boot, if the boot has split then water and crud has got into the joint and it will fail. The process of re-booting is the same as complete joint replacement time wise, so you might as well just fork out for a new CV and not have to have the job done twice.
Depending where you go, 150 to 180 ish fitted.
brendazworld, Sep 22, 8:27am
awesome!Thanks for the advice!
unbeatabull, Sep 22, 1:47pm
IF the CV joint is fine and you're pressed for money, you can get "Stretchy" CV Boots that just slip over the joint without having to disassemble it all. Takes 1/4 of the time, so obv less labour cost. Usually around $60 fitted.
dasfi, Sep 22, 1:57pm
Be easier to buy my celica
