Yamaha AG100
t1ny01, Sep 16, 9:28am
Hi I have a old AG100 I'm try to get going again - The motor runs because if I put a little 2 stroke in the cylinder and but the spark plug back kick it over it runs but unsure of how to plumb the carb back in (I got this bike in bits) can any one help I want to premix the fuel if possible. Thanks
kaymay88, Sep 16, 9:44am
so what exactly are you struggling to do! no reason you can run it on premix, alot of people do exactly that.
t1ny01, Sep 16, 9:52am
I want to get the fuel tank and carb all hooked up so it runs just not sure what goes where
kaymay88, Sep 16, 10:01am
it should be pretty self explanatory, but if you are having issues do a google images search on 'yamaha AG100 exploded view' and you should be able to see,
there should be something like this http://www.ebay.co.uk/itm/YAMAHA-RXS100-RXS-100-CARB-CARBURETOR-INLET-RUBBER-/360487343102!pt=UK_Motorcycle_Parts&hash=item53eeb853fe#ht_808wt_1037 that bolts onto the motor, the card slots into the round part, and is secured with a hoseclamp.
as for the tank, there should be on the frame near the headstock (the front of the frame near the forks, look on either side of the frame) two little nodes, or bits that stick out from the frame, these little bits should have a little rubber cover over them. if you look at the underside of the tank you will see how they slot into the tank when you slide the tank onto the frame.
kaymay88, Sep 16, 10:02am
when looking at the top of the tank you will see a hole that is for a bolt that is used to secure the tank to the frame, should be somewhere near where the tank would meet the seat.
does this help at all!
these are very simple bikes, and if you are having trouble figuring out how it goes together, its possible you are missing a couple of bits and pieces!
t1ny01, Sep 16, 10:06am
Awesome Thank you I knew if I asked here someone would know.
Appeciate your time
kaymay88, Sep 16, 10:15am
no problem! let us know how ya get on
t1ny01, Sep 16, 11:05am
Ok feeling really stupid now! I have carb attached to engine have throttle cable hooked up and works have fuel line from tank to carb and still 3 hose connections left where do they go!
Help
kazbanz, Sep 16, 11:20am
you will have the oil line from your oil pump for one then theres likely to be a breather pipe. The AG MIGHT have a vac tap.
