Would a s15 engine plug into a s14 loom?
erik., Oct 19, 7:24pm
would a s15 engine plug into a s14 loom! if not what would be the differences
lazz323, Oct 19, 7:34pm
get b18cR :) no problems at all plug and play like a likn G4 ^.^
bubbles244, Oct 19, 7:44pm
erik., Oct 19, 7:51pm
thanks that relay helped
falcon15, Jan 6, 1:49pm
aslong as your not going from non turbo to turbo engines the s15 turbo engine will mostly plug in but you will need to use the s14 ignitor and coils and also the injectors if the s15 engine was from a spec r
