Just replaced the drive belt on a 50cc Scooter now
spudster,
Oct 23, 9:01pm
it won't start. it is trying to fire but won't. It seems like the belt is to tight and the brake has to be held on when you are using the starter. This seems like there is to much restriction on the starter. The belt is the same as what came off it. Thanks
jmma,
Oct 23, 9:02pm
Cool story, Bro(o:
outbidyou2,
Oct 23, 9:04pm
wow jmma, look at your trades!
jmma,
Oct 23, 9:10pm
Been around awhile (o:
outbidyou2,
Oct 23, 9:16pm
like a dirty ol 50
petermcg,
Oct 24, 4:29pm
When you dismantle to fit the belt, do you go any where near the fly wheel where the alternater might be,, could be just a wire or an earth.
sturmiearcher,
Oct 25, 6:06pm
Knocked the vacuum hose of the fuel tank tap or the other end if it has the vacuum hose ! Fits on somewhere around the inlet manifold I think !.
pedro.b,
Oct 25, 7:53pm
Did you squeeze the rear clutch pulleys apart so the belt has some slack in it! A new belt will always be a bit tighter to start with until it runs in but. But if the pulleys are pulled apart when the belt is installed it should be slack until started up, then the variator will adjust to the correct tension.
spudster,
Oct 25, 7:58pm
The Variator weights had moved when the belt snaped. once I removed it and put the weights back properly, it started and ran properly. Thanks
