Soo Driving at slow speed changed gears and rpm dropped and turned off. Tried to start again but just got solenoid engaging and not cranking. Then tried push starting several times with nothing just the motor jolting and not turning.
So far ive tried to rotate the motor by hand - wont turn stiff as fuck! not even with a rattle run. had front wheels off the ground had it in gear 5 and rotated the wheels just to find they spin freely but the motor still jammed.
Motor has good oil and coolant and was not subject to overheating etc at the time.
Seems to me like a twisted flywheel or something!
Details:
99 hyundai lantra 5spd manual 1.6dohc 199xxx km
a.woodrow,
Oct 29, 7:16pm
The cambelt has broken
jmma,
Oct 29, 7:18pm
Snapped cambelt!If they have one (o:
pentium4,
Oct 29, 8:07pm
Cambelt is sweet! Just checked now
jmma,
Oct 29, 8:22pm
May have stripped the teeth off, may need to take cam cover off and see if valves are sticking down (o:
Oct 29, 8:25pm
What's the clutch feel like!
pentium4,
Oct 29, 8:32pm
clutch feels 100% normal and have had rocker cover off - all is in tact and golden
Oct 29, 8:38pm
The engine will be a DOHC, the camshafts are connected together with a chain (one cam is belt driven which also drives the other cam via a chain). As above, pull the rocker cover off and examine the chain and valves and shit.
snoopy221,
Oct 29, 8:38pm
Tried turning it BACKWARDS! If it has dropped a belt and valves are hitting it will turn backwards a bit-but won't go forward.
Oct 29, 8:39pm
Can you rotate / rock the cams slightly!
satans_child_nz,
Oct 29, 8:50pm
siezed buddy
pentium4,
Oct 29, 8:53pm
Tried turning it both ways backwards and forwards from cam pulley and bottom pulley. Nothing - just stiff as it gets. Will investigate that chain as it may be the cause. any other things to look at!
satans_child_nz,
Oct 29, 8:59pm
IMO youll find the pistons wont move up or down but the cams will turn, ive had a car sieze on me with good amount of oil/water. hence the rpm drop, as the engine became jamned up
mecanix,
Oct 30, 6:49am
siezed engine or broken cam belt, most likely cam belt. the teeth at the crank pulley will be stripped.
either way, its goosed.
