1984 Honda coupe 5 speed gearbox query
jetmouse, Nov 10, 8:05pm
This model made from 82-84.Will any 5 speed from say a 78- 84 fit! I have been advised that the box is specific to this model and other 5 speeds wont fit but seek other opinions. I have the specs in my auction seeking replacement box. Thanks to any who could advise.
thegravelracer, Nov 10, 8:24pm
nope the box isn't specific to the model of car only the model of motor
jetmouse, Nov 10, 8:34pm
If i understand you correctly, model of motor meaning all models fitted with the 1600 8 valves have the same 5 speed gearboxes!
thegravelracer, Nov 10, 9:38pm
nope ,have a look at a section on the block close to the gearbox there should be a flat part with a id type imprint for example if you have a zc 1.6 motor it will have zc printed on the block same iwth a b series engine d series ect ect so when you find out what engine type you have then you will be able to find out what gearbox you need i.e b series block /b series g box .you catch my drift!
thegravelracer, Nov 10, 9:39pm
honda =lego
jetmouse, Feb 17, 3:51am
Yep, got that, thank you so much, appreciate your reply.
