Car not starting. Maybe you need water in the window wash bottle
johnf_456, Nov 10, 7:22pm
Has it got petrol
ginga4lyfe, Nov 10, 7:22pm
maybe you need water in the window wash bottle!
ginga4lyfe, Nov 10, 7:24pm
is the space saver missing!
ginga4lyfe, Nov 10, 7:25pm
OH i know! Its your bumper, its Skew
fern413, Nov 10, 7:26pm
Is it turning over! If not turn the lights on if theyre dull batterys flat
ginga4lyfe, Nov 10, 7:26pm
that or its got a lada badge on the front, you may need to replace the engine with a Farmall Tractor engine, that way you gain more power/speed too
jmma, Nov 10, 7:28pm
Turn the key man (o:
fern413, Nov 10, 7:28pm
Put the joint out and turn the key
ginga4lyfe, Nov 10, 7:30pm
nah that wont work, he has no key for it so has to hot wire it with paper clips
alimac1, Nov 10, 7:48pm
ideas are overrated anyway, especially if they are started by a car
solarboy, Nov 10, 7:59pm
Another thread starter( unlike the car ) with no useful information given !Some clues huh, like what colour is it and if it's on H P are you up to date with your payments /
carmedic, Nov 10, 8:03pm
Yes good point there, the finance company may have remotely locked the ECU if you??
jmma, Nov 10, 8:06pm
Is there a whining noise or is that yet to come (o:
tmenz, Nov 10, 8:59pm
Try saying, "Ready, Steady, Go".
a18a, Nov 10, 9:50pm
You've obviously ran out of accelerator fluid.
icemans1, Nov 10, 11:03pm
sounds like a problem with the flux capacitor
andrew499, Nov 11, 6:53am
have you tried asking it nicely to start!Failing that, gnashing teeth, banging head against steering wheel or turning on the waterworks might do the trick.otherwise, it's bound to be the anti driving licence detector shutting down all systems.if your licence is up to date, then the detector probably came from a faulty Chinese batch.
kiwikidd77, Nov 11, 7:26am
I told you and told you not to remove 6 of the 8 cylinders if you want to get going.
gmphil, Nov 11, 7:09pm
need push x button to start
h.e, Nov 11, 7:54pm
they're spare parts, a job isnt done right unless there is spare parts.the last bloke who worked on it left them in your sump so as not to lose them,nice of him really i would have put them in my spare part box for future use
h.e, Nov 11, 8:06pm
jump start it ,chuck 24 volts up it that will get the starter really spinning,it will have no choice but to start
jmma, Nov 11, 8:09pm
Piston broke (o:
Typical kiwi bloke.
kiwikidd77, Feb 20, 9:43am
Just throw it away and reassemble before use. it will still work OK.
