Estima hard to start cold
imafreespirit, Nov 13, 12:04pm
Hi I have a very annoying problem trying to start my toyota estima in the mornings or when its been sitting for more than a day or so. Its a 1992 petrol auto. recently I had the engine replaced. For a while when I got it back there were issues with the throttle position sensor causing idle problems which is now fine. It was getting hard to start sometimes then but now its worse. It also create quite a bit of condensation when started from cold then goes away after awhile.Took 4 turns to start it. Could it be the sensor still not right or something fuel or ignition related!
imafreespirit, Nov 13, 12:38pm
that's from the old engine. That engine is gone. The new engine is fine while warm. its just hard to turn over. once fired up its fine. something not set right when the mechanic put engine in but I don't know what exactly.
