So you know how a lot of the jap imported cars have a huge screen on the dash that is unable to be converted to english! Is it a simple thing to remove this and install your own stereo/radio ect! Ive been looking at a few imported cars but they all seem to have this problem. T.I.A
Nov 8, 7:16am
often its not so simple to do depending on car. like i done one on a mazda capella need to make up blanking plate and mess abouts with the wiring for a long time to figure what was what. I usually tell people to pi$$ off with radio fitting because its never easy unlessyou buy conversion plugs and the same size unit that was in there.
robotnik,
Nov 8, 7:20am
Sometimes these touch screens also control the heater and the air conditioning. If this is the case then you pretty much have to keep them and learn Japanese.
sketch_mad,
Nov 8, 7:21am
o.O ok thanks i shall be looking for ones with proper stereos!
Nov 8, 7:25am
dont buy a car for the stereo lol
sketch_mad,
Nov 8, 7:39am
lol i have my eye set on toyota corollas i'll just pick one with out a jap screen :P
Nov 8, 7:40am
My gosh a lot of utter rubbish being talked. In MOST cases its a pretty easy job swapping out the factory sterio/gps for a kiwi sterio and a pocket underneath. In some specific/rare cases its not an option Cars i know of as being an issue. SOME honda odysseys,ALL mazda demios 2002-2006 ALL toyotas need a special "fit kit" which consists of 2 specially shaped plastic fillers/brackets to take up the extra 9mm that toyota sterios are wider than a normal sterio.-adds about $40 to the price. Rule of thumb is that if the sterio is double the size of a kiwi sterio then a kiwi one will slot in with little trouble. EDIT--Ihave not found ANY corolla or corolla variants where a kiwi sterio doesn't just bolt straight in. WITH the discussed fit kit and pocket under. I sell about 10-15 Toyota's a month
Nov 8, 7:40am
Op -ALL toyotas need a special "fit kit" which consists of 2 specially shaped plastic fillers/brackets to take up the extra 9mm that toyota sterios are wider than a normal sterio.-adds about $40 to the price. Rule of thumb is that if the sterio is double the size of a kiwi sterio then a kiwi one will slot in with little trouble. Ihave not found ANY corolla or corolla variants where a kiwi sterio doesn't just bolt straight in. WITH the discussed fit kit and pocket under. I sell about 10-15 Toyota's a month.
