The list at Super Cheap Auto said Shell Helix HX5 15W-40 (among others) is the correct oil, so I bought that. Since then I found in the owners manual online (don't have a hard copy) that 10W-30 is the correct oil, then online in another forum it said something different. So what I want to know is what do the numbers mean, is the oil I have something unnecessarily better or something completely different (damaging)!
FYI: Haven't put any in the engine yet.
Also, just bought the RAV second hand, so I don't know what oil is currently in it, what do I need to do since I am more than likely going to be mixing two different oils (if not the type then atleast the brand).
Thanks
a.woodrow,
Nov 10, 7:50pm
either oils mentioned will be ok
Nov 10, 8:07pm
What's currently in your RAV4's engine is irrelevant, but being an old oil leaking pig, 15w-40 of any brand will be fine.
r15,
Nov 11, 6:36am
this is the first i've heard of the 3s engine series being prone to leaks. but still 15-40 will be fine
Nov 11, 6:47am
rav 4 are not exactly good toyotas . i got one outside with broken off Feft front axle-snapped CV Nut-off and pissing oil out like hell when it runs. . another person i knew blew up the automatic trans on rav4. The reason i could think off doing that be uneaven tyres on a permanent 4wd , just to warn you about a few well knowen issues of these.
chebry,
Nov 11, 7:27am
Christ Rav 4s only have a Corona engine
Nov 11, 8:08am
I'm yet to see one that doesn't leak.
Nov 11, 8:10am
Early RAV 4 is pos in my opinion. Why people pay such high prices for them is a mystery.
johnf_456,
Nov 11, 1:29pm
For the badge.
robbo36,
Nov 11, 3:09pm
All vehicles with rubber oil seals and gaskets at that age, (18 years) will tend to leak oil as the rubber ages and hardens. If it was my vehicle, I would be running 20W50 in it.
zooki007,
Nov 11, 3:26pm
Castrol Protec 15w40 is what we use in them at work (Toyota Dealership). The 3s engine is a very reliable engine and only has issues when neglected.
