Car radio Fuse ?
doggybear, Nov 13, 11:16am
Got into my car other night (94 toyota Camry ) turned ignition but no lights at all come on with no engine turn over-great I thought "flat battery" but thought it odd that it had gone completely flat. We opened bonnet and wiggled battery connections which i didnt think too bad but lights came on and car started no trouble. The only thing now is the car radio wont come on only backing lights on radio. Would a carsradio short circuiting disrupt the whole electrics ! I have checked all fuses in box seem ok-are the fuses located inside the radio itself! Thanks for any help :)
jmma, Nov 13, 11:17am
Think you might have to put a code in to make it work again.
doggybear, Nov 13, 11:19am
thanks How the heck you do that !
mackenzie2, Nov 13, 11:21am
Ring Toyota and give them your plate # they will then give you the code,
jmma, Nov 13, 11:23am
Just drive into Toyota dealership, if you don't know how to do it (o:
doggybear, Nov 13, 11:27am
wow-I never knew that-Thanks :)
luxy, Nov 13, 7:37pm
if its a late toyota use the last 3 or 4 numbers of the vin. Toyota will no longer give it over the phone if its a older one. they are supposed to sight the car
