Hi all you legends, just putting a car stereo in MILS car, The does not appear to be a earth wire in the loom! Has anyone come across this! I don't want to try wiring it in without an earth. Mitishi Mc-H 710 radio going in a 95 caroller
skyline_guy_r34,
May 25, 2:53pm
If there is no earth chances are the old radio earthed itself when bolted into its spot. You can do the same without too much worries. Or if you are concerned you can run your earth wire from the headunit, put a ring connector on it and just screw it into a bolt (thats metal and is screwed into metal) inside the console somewhere.
johnf_456,
May 25, 2:56pm
As above just use something metal nearby
bigracket,
May 25, 2:58pm
Ah yes the is a spade terminal on the back, Got it cheers Skyline.
bigracket,
May 25, 2:59pm
And Johnf_456.
skyline_guy_r34,
Mar 31, 7:41pm
I was meant to say ring terminal, but if you found a spade terminal with the earth wire from the car. even better.
