Poptop Camper Tyre Pressure?
yendor, Nov 26, 12:50pm
We have a Poptop Camper, weighs around 800kg, has 165r13 8 ply tyres. What sort of cold pressure should I run!
bill-robinson, Nov 26, 12:52pm
anything on the drivers door pillar! or the edge of the door by the catch!
franc123, Nov 26, 1:09pm
being 8 plys and on single axle I'd aim for 36-40.
splinter67, Nov 26, 1:20pm
Bill its a caravan not a car
theram1, Nov 26, 1:50pm
Try a tyre shop, they will know the right pressure.
mrfxit, Nov 26, 4:15pm
30 to 35psi should be fine.
Wouldn't run them at anything higher then 35psi.
At or lower then 30psi would overheat them/ wear the edges fast & be susceptible to pothole punctures.
Higher then 35psi would possibly allow it to slid on wet roads & wear the centers fast, also bumps are harder on the chassis/suspension
mrfxit, Nov 26, 4:16pm
Try 35psi, if it feels too soft on the road then up it to 38psi.
If it feels too harsh, then drop it to 32psi
2 psi either way can make a heck of a difference
Each trailer & load can effect tyres & handling differently
