Sump bung on a vx 2001 commodore! I am not having much luck finding one. The head of it is a 19mm but what thread size do I ask for to buy one! Would be awesome if anyone can help thanks
Open up the drain plug catalogue. Has all you need to know, and part numbers for a replacement.
doug207,
Dec 16, 12:02pm
Pull it out and measure it!
trade4us2,
Dec 16, 12:50pm
Measure the thread. It's probably 14mm X 1.5mm pitch. Put a ruler on it. Count 8 threads and that should be 12mm.
1hotgloria,
Dec 16, 1:39pm
i cant get it out at mo to measure it, as its been rounded off as was done up far too tight so am thinking drastic measures to get it off but dont wanna take it out yet as live rural so cant get another sump plug to put back in straight away which is why i need to know what to buy first so its on hand at the time
trade4us2,
Dec 16, 3:05pm
Well it's probably Metric Fine 14mm 1.5mm pitch. You'd think everyone would be discussing the size on the Net, after all the complaints about rounded heads. I don't see why an ordinary bolt won't fit there instead of the standard part that has a head that's too narrow.
the-lada-dude,
Dec 16, 3:43pm
spark plug. or cork
howz_that,
Dec 16, 4:37pm
It might be Imperial
afer_daily,
Dec 17, 2:25am
cut it out with a gas torch .
bjmh,
Dec 17, 6:51am
i brought a new one from Holden dealer can't remember cost but wasn't over the top,small stilsons sometimes will get damaged one out
saki,
Dec 17, 2:54pm
If you wont to replace it with a normal bolt goodluck finding 14mm
rickroller,
Dec 17, 3:52pm
Just click on the link in the second post. It has your answer.
ozz1,
Dec 17, 4:06pm
just weld a bigger nut onto it.problem solved.wouldnt take too much to do.!
trade4us2,
Dec 17, 5:14pm
I look after about 20,000 bolts, including 14mm MF.
