Can I put the number plate on the trailer guard. Is it legal to put the number plate and light on to the mud guard cheers
tnt423, Dec 22, 11:31am
Is it legal to put the number plate and light on to the mud guard! Cheers
ralphdog1, Dec 22, 12:17pm
Wrong
jonthefisho, Dec 22, 2:10pm
Mine is. never had any problems getting w.o.f
from vtnz.
socram, Dec 22, 2:30pm
Mine have always been there too.No problem.
msigg, Dec 22, 2:34pm
Same as above. Go for it. Nothing wrong with that.
meathead_timaru, Dec 22, 6:33pm
Yes.
http://tinyurl.com/d7ah3hw
Probably because the registration plate has absolutely nothing to do with a WoF.
meathead_timaru, Dec 22, 9:22pm
Lights are a little different - there are prescribed positions and angles of visibility. Here they are:
http://www.nzta.govt.nz/resources/rules/vehicle-lighting-2004.html
franc123, Dec 22, 9:40pm
Plates are now required to be horizontally mounted, this has been the case since last year when a number of rules were changed or clarified re the display of plates. As long as its mounted and illuminated correctly on the guard and isn't an external projection that could be a danger to cyclists or pedestrians, no problem.
mber2, Dec 22, 9:41pm
So long as the number plate light is also on the guard with the plate then yes
stabi360, Dec 22, 9:42pm
doesnt it have to be seen within a certain angle on both sides of trailer at the back! to get a wof
so in that case no its not legal to have it on a trailer guard
meathead_timaru, Dec 22, 9:54pm
No, there is no angle requirement for the registration plate illumination lamp as there is for stop lamps.
meathead_timaru, Dec 22, 10:02pm
frytime, Dec 23, 12:07pm
no white light to the rear
