Running out fuel 4 storage on outboard good or bad
geminidragon,
Dec 29, 3:12pm
i have a v140 yamaha which i intend to store for 4 months question is leave fuel in outboard or run it out cheers
theram1,
Dec 29, 3:15pm
Out.
kingfisher21,
Dec 29, 3:23pm
Run it out or remove the drain screws on the carbs, that's if it is a carbed one.
bwg11,
Dec 29, 3:23pm
Four months is boarderline in my opinion. When I know my boat will not be used for several months I fill will 95 octane as it is said that octane rating declines with storage, it will hopefully still be at least the required 91. You could use the storage product - Stabill - expensive - which I have also used over winter. Don't know if it does any good, but I haven't had any fuel storage issues. I think the issue isn't if petrol still works after long storage, but if the octane rating is still high enough to prevent detonation and holed pistons as outboards are often run for long periods at WOT.
geminidragon,
Dec 29, 4:25pm
last season i had left it in and it was a bitch to start ,guess it went bad ,i had left it in as i had heard it would keep the carb seals from distorting ,,shrinking and its a carb engine thanks
Dec 29, 4:39pm
Fill it with 98 octane BP fuel
drog,
Dec 30, 5:49am
Why not leave a small quantity of fuel to keep the system 'wet', then thoroughly drain and fill with fresh fuel at next startup!
geminidragon,
Dec 30, 9:53am
because its a mission to get to the brass drain plugs
