Am thinking of buying a Subaru Outback, any advice
agave1,
Dec 30, 6:35pm
Am looking at around 2004-2006, $12,000-$16,000, under 100,000kms on the clock.
Will be doing some minor off-road driving, e.g. paddocks, snow on roads, dirt roads, etc.
Any issues!Was thinking of a Subary Legacy but Outback is a bit higher off the ground.
I am not mechanical, will be keeping it serviced. all I want is a 4wd decent length stationwagon that doesn't break down and will last a while without needing much spending on it.
thanks.
neo_psy,
Dec 30, 11:18pm
Got an 04 Legacy - really like it.
much like everything, get as much of a service history as you can and keep it serviced. Non-turbos are less likely to have been raped.
michaelqian,
Dec 30, 11:39pm
Generally very reliable vehicles. Between 2004 and 2006 no Outbacks had turbos, not in NZ anyway.
dave.sparky,
Dec 31, 5:50am
I have a 2000 Outback done 280000kms,Father in law has 2004. Both are the H6 3L motor. No problems with them at all. Keep it serviced and they are a great car , ok on fuel, great tow car.
lookoutas,
Dec 31, 6:34am
I'd go for an H6 as well. Don't stop at just paddocks, they can handle more than that. Subaru AWD is the best on the market. I saw a doco once where they tested different makes on a ramp with rollers, and the Subaru got the furtherest. Always makes me cringe when I see that add on TV where a Subaru is being towed up a track with a tractor. Subaru should kick that Fraser guy up the arse, coz there's no way that car needs towing up there.
