Falcon still hasdrum brakes on all four corners and i want to upgrade to discs and pads. has anyone done this on an old falcon! Cn anyone tell me what parts i shoould be lookin for!
lookoutas,
Jan 8, 5:15am
Easiest fit would be XW/Y, otherwise you start comparing with complete stub swap to XF. Watch the steering arm position/height in comparison to XR, otherwise you'll get bump-steer. Then just chuck in a complete XF diff. Good idea to use the master cylinder as well
splinter67,
Jan 8, 5:53am
Use xfyou should change the whole assembly that will also get rid of the dreaded falcon squeak
lookoutas,
Jan 8, 7:02am
Yeh splinter - using the XF top arm is a real good idea. Must change mine one day. If using the bottom arm, it should have larger inside bolts, so the X member will need drilling out.
splinter67,
Jan 8, 7:09am
exactly easy job to do
