Like magic because it would change gears all by itself!
Jan 24, 7:30pm
Very good, I'm assuming you are talking about off road use.!
If so, in low range 4WD mode it will lack descent control. Which in itself is not a problem once you master the left foot braking [you gently apply the brake with your left foot (and keep it there) and use the accelerator to over ride the brakes].
johnf_456,
Jan 24, 7:30pm
Take it for a test drive and see how you like it
bwg11,
Jan 24, 7:40pm
20 years ago, I would not dreamt of having and auto 4 X 4. Now, I would not even consider buying a manual for off-road use. The only proviso would be the addition of an auxillary oil cooler for the transmission for heavy duty usage or towing,
NZTools,
Jan 24, 7:44pm
What they lack on downhill control, autos more than make up for in climbing and negotiating rocks etc. a torque converter is brilliant for creeping.
Jan 24, 9:26pm
Yep, I too prefer autos for off road use. Much easier.
