Towing with a-frame
robbief, Feb 6, 10:33am
can a 1994 rav4 be towed on a a-frame there seems to be some changes made in 2010 with what can be towed bit confused with year and weight
msigg, Feb 6, 11:15am
I think you can tow most things with an A frame, the problems arise with the gearbox not circulating oil in the towed vehicle.
robbief, Feb 6, 12:07pm
thanks for that i will have to check that out
johnf_456, Feb 6, 12:40pm
only really with automatics.
msigg, Feb 6, 12:57pm
No john you do get problems with manual as well, I know someone that did just this to their datsun 1200 towiing from Auckland to Taupo, bun't out gearbox, so don't assume all is equal. Do research.
elect70, Feb 6, 1:07pm
^^well see quite a few camper vansA frame towing SUV s behind them .Cant see how it would be a problemthe lay gearsconstantlyturning if car is moving , there by picking up oil &spreading itovermain shaft & gears
martin11, Feb 6, 1:16pm
Rubbish gears will still be moving the oil around ,many large vans have little 4x4 behind in Aus with no problems
msigg, Feb 6, 1:21pm
Yes well the rav might be ok I don't know about that one , but car can be a problem. Talk to your transmission specialist first. That's the best advice.
robbief, Feb 6, 1:29pm
thanks for the help its a manual so gears should get oil with gears going around
stevo2, Feb 6, 1:29pm
Most small SUV's towed behind campers are Suzukis because they have a Hi/lo transfer box that can be left in neutral therefore meaning the whole drive train is not spinning.
desmodave, Feb 6, 1:34pm
Would a single axle car trailer be a better option ! it would save a lot of wear on the car .
johnf_456, Feb 6, 2:10pm
firstly dont name call it isnt nice and that is why i said really (mainly) rather than saying only automatics!
NZTools, Feb 6, 2:23pm
If the layshaft is mounted at the top of the gearbox it often doesn't get the front bearing lubricated well if it is only the tailshaft slinging oil.
smac, Feb 6, 2:35pm
The issues you may have heard about relate to what vehicles can have changes made to the front of the vehicle to fit an A frame. It all relates to frontal impact standards. Motor Caravan Association seems to be best source of up to date info.
snoopy221, Feb 6, 2:41pm
Yip.
Best post so far In My Opinion.
Oh and as to the common everyday speed hump-[don't name call]
Gor Blimey.
Ya juss know when a username has (x) in it and someone is referred to as (x).
well there are usernames and then there is.
meathead_timaru, Feb 6, 3:24pm
You'd be a bit of a sensitive droob if you were a sunken-chest wannabe like him.
morrisman1, Feb 6, 3:57pm
Why would that matter, the front bearing isn't turning when its sitting in neutral with engine not running. As long as the layshaft is getting its bearings lubricated then all should be fine and dandy.
NZTools, Feb 6, 4:38pm
I was talkin about the front bearing of the layshaft
thewomble1, Feb 6, 10:54pm
No difference to the car being towed ifusing a rope or a 'A' frame except when using a rope you will need an extra driver. Won't be able to use 'A' frame if the towed vehicle is an automatic.
robbief, Feb 7, 5:54am
this is a nanual and what is the impact law when it has a chassie!
desmodave, Feb 7, 6:16am
And if that automatic has the transfer case placed in neutral while being towed whats the problem.
mrfxit, Feb 7, 7:18am
Towed many many vehicles over many years & NEVER ever had issues with gearbox's, auto OR manual
Auto's were towed no faster then 50kph MAX & only for about 5km's distance max (normally across town)
Manuals had been towed anything up to 400km's in 1 trip.
mrfxit, Feb 7, 7:23am
When in doubt or misquoted .>>
LOOK UP THE MANUAL or even better RING TOYOTA about towing recommendations.
(Caps for the nearly blind)
robbief, Feb 7, 4:42pm
rang the toy motor shop and there is no problem said go for it thanks for all the help
cowlover, Feb 7, 4:50pm
Hope you got that in writeing.May not be a problem but if there is it will be expensive.
