Given the following details how many hours do you reckon would be appropriate to do the work!
Sonata 2 ltr auto Towed to workshop Replacement engine (complete) on pallet Cam belt kit inc pump supplied.
So essentially its pluck old , do cam belt etc and fit new.
I know what I think and I know what the customer was quoted elsewhere.Just after your thoughts.
mm12345,
Feb 13, 9:55am
Would want to have a very good look at how much plumbing is involved and how easy is it to get to it all - "little" things can take up a lot of time, ie are manifolds supplied with new engine! Also, the second time you did one of this model, it's probably going to take much less time than the first. A guess would be 10 hours (including stuffing around with the new cam belt, replacing the water pump, and replacing the rear main crank seal - which is a very dumb thing not to do with an engine which has probably been sitting in a dusty shed for a long time.+/- 4 hours.
phillip.weston,
Feb 13, 10:18am
it's essentially a Korean-ised Mitsubishi Galant. You'll find it's exactly the same job as a 4G63 DOHC engine from the late 80s/early 90s to do the cam-belt job on.
supernova2,
Feb 13, 6:38pm
Bit more info is a year 2000 only part "missing" from replacement is alternator
and the quote was $2000 +gst + fluids etc
robotnik,
Feb 13, 6:56pm
$2000 sounds pretty good, doing cambelt too. I remember being quoted around $2500 + GST5 years ago for to put a replacement engine in a galant.
supernova2,
Feb 13, 7:00pm
Hang on the quote is just to fit not supply the engine
Its work out based on 22 yes 22 hours
llortmt,
Feb 13, 9:30pm
I'd quote 16 hours so around $1k + gst and any parts/fluids etc
I've heard that before, one turns out to be auto and the other manual, engine loom and every hose etc cut by animals working at wreckers oh and hold on the sumps different!
supernova2,
Feb 13, 10:43pm
Too true but in this case I've seen the replacement engine and its a straight drop in the hole and hook it up.Its clean but it hasn't been cleaned if you know what I mean.I reckon 9-10hrs would do it unless it's stubbon and refuses to start or something stuipd
gadgit3,
Feb 14, 5:09am
Most front wheel drive cars I would estimate 10-12 hours. Alot of them you can just drop the sub frame and work away on the engine swap unhinded.
llortmt,
Feb 14, 5:14am
The book time surprised me at 18 hours to remove and install.
