Oil/grease marks on concrete
rainrain1, Mar 9, 8:48am
does anyone know of a way to clean thanks
bill-robinson, Mar 9, 9:40am
bleach, water, and scrub with a stiff brush
neville48, Mar 9, 9:55am
if stains are still there after the oil has been removed, use CLR. Mitre10 Mega have it for 20 bux, it is mildley acidic and also helps tp put the lighter coloured bleached look back into the concrete.
rainrain1, Mar 9, 12:33pm
Thanks neville48, will give it a go.
will try the bleach first
beast9, Mar 9, 7:37pm
if its on concrete pour some petrol on it to soften it then sprinkle a reasonable amount of cement powder on it and leave it for a bit then brush it up and hose off works well to
kevymtnz, Mar 9, 7:42pm
scrub with laundry powder hose off
morrisman1, Mar 9, 7:44pm
just do a skid on it.
franc123, Mar 9, 7:58pm
washing powder is the most effective if you haven't got access to anything else or don't want to splash out on fancy chemicals.
treachug, Mar 9, 9:20pm
Wet & forget Shower Witch is great for removing oil stains from clothes, driveways etc.ohh also works on showers like it was made for.lol
rainrain1, Mar 10, 6:15am
the mind boggles
supernova2, Mar 10, 8:36am
A scub with kero, rinse with a hose,thenthe laundry power will work better.
strobo, Mar 10, 8:55am
red /black spray can of degreaser $5 odd from suparrrcheeep autos then simply hose off ,not into the storm drain though! " envoirnmental (sp)issues" the oil or grease may disperse but the stain will probably remain , maybe caustic soda Sodium hydroxide (NaOH),or something acid may get it finally.with a light dusting of fine sand.
rainrain1, Mar 10, 9:36am
I am now spoilt for choice, eeny meeny miny mo.ta everyone
budgel, Mar 11, 11:34am
Come back when you have done it and tell us what worked!
tup, Mar 11, 12:19pm
Degreaser.just did it this morning to the oil stains here. whipped them off no worries. ,and CHEAP!I've tried all sorts of stuff that didn't work before finding simple and cheap degreaser in a can.:)
pfemstn, Mar 12, 5:50am
brake clean or similar works well also! spray on wipe off
timmo1, Mar 12, 9:01am
Avoid the '30 Seconds' degreaser spray- I got some from Bunnings and it is absolutely useless- Doesn't cut through any grease, let alone automotive related oils and grease.
The Supercheap stuff is pretty good for small stains etc.
texastwo, Mar 12, 9:25am
On another thread elsewhere the suggestion was cocacola. Cant see it myself.
neville48, Mar 12, 7:31pm
"Things go better with Coke" so it must work!
reeve2, Mar 13, 6:49am
let laundry powder absorb mess for a few days then scrub up.
